    Dismiss Notice
Stupid thoughts about durability of modern building materials
Discussion in 'General Discussion' started by jacko555, 8 Aug 2020.
Tags:
  1. jacko555
    jacko555
    5 Feb 2005
    146
    Thanks Received:
    17
    Country:
    Ok, odd chat with wifey and wondered what people's thoughts are on the subject of the longevity of modern building materials...
    What triggered this was an inspection of the attic of the house we have purchased. 100 years old, original roof, brick walls, floorboards in the attic. Surveyor said attic was sound. No leaks. All good. Would easily last another hundred years..
    Wifey and I drive past a different house we considered purchasing. New owners are converting the attic on that one. We've got to see progress as we drive past weekly.
    They've removed the roof, built an OSB shell, insultation, new tiles etc.
    Wifey said : I wonder if that'll be there in a 100 years.
    That piqued my interest. Osb was invented in the 60's. Theoretically plastics/resins last forever, but, we've all seen old plastics, and they get brittle. They dont like sunlight, extended heat etc. It may take thousands of years to fully biodegrade, but, how long will it last a decent structural component before it gets brittle, start to delaminate, fail?
    Same with EPS insulation. Yes, polystyrene lasts "forever", but, it goes dusty and crumbly way before that.
    So, yeah, stupid question really, just wondering what people's thoughts are on the subject...
    We all see old houses, but, will the modern Barratt Palaces still be around in a hundred years?
  2. Sponsored Links
  3. freddiemercurystwin
    freddiemercurystwin
    21 Jan 2007
    18,802
    Thanks Received:
    2,082
    Devon
    Country:
    Typically Barratts and the like are designed for a 50 year lifespan.
    • Like Like x 1
  4. pete50
    pete50
    19 Mar 2017
    678
    Thanks Received:
    130
    Country:
    When I came out of the army in 1977 we went to look at a Barratt house. It was a complete pile of junk then and house building has not improved since in my opinion. Junk builders are building junk houses out of junk. The three houses that we have lived in since 1977 have all been early sixties or older. Solid walls proper foundations only drawback that I see is that the floors have been wooden and when the floorboards are lifted you can see the ground underneath. I haven't encountered any problems with that but I would have thought a concrete slab would have been better.
    • Like Like x 3
  5. Brigadier
    Brigadier
    14 Jan 2008
    8,182
    Thanks Received:
    586
    Staffordshire
    Country:
    Clay will last thousands of years.
    So, if you want something to last long after you're gone, spec a well-built roof structure with properly-laid clay roof tiles.
    I read a quote once about how to demolish a building : "Make an 18" square hole in the roof, stand back, and wait. "
    • Like Like x 3
    • Thanks Thanks x 1
  6. Notch7
    Notch7
    15 Sep 2017
    19,021
    Thanks Received:
    1,336
    Sussex
    Country:
    I thought it was only until the cheque clears :ROFLMAO:
    If you buy a new house make sure your phone has the snagging team on speed dial.
    I would never buy one from the big 6 housebuilders..........driven by shareholder profits not customer satisfaction.
    • Like Like x 1
  7. Ryler
    Ryler
    21 Oct 2019
    2,101
    Thanks Received:
    152
    Country:
    A cave with a stone roof will last the longest. Probably thousands of years.
    A flat roof made with a big concrete slab would last a long while too.
    • Like Like x 1
  8. EddieM
    EddieM
    15 Feb 2009
    9,366
    Thanks Received:
    539
    Country:
    IIRC new houses are built to last 100 years and must comply in terms of energy efficiency. After that they are simply built to the lowest cost / maximum profit.
    That said, if you had land with PP, plenty of money & a knowledgeable builder then, yes your house in theory would be significantly superior to any old house.
    • Like Like x 2
  9. bennymultifinish
    bennymultifinish
    21 Apr 2020
    1,651
    Thanks Received:
    266
    Country:
    in the 50s 60s and 70s houses, particularly social housing were thrown up with top quality natural materials. which was they’re saving grace.
    now new builds are thrown up with lightweight manufactured budget materials that are not produced or erected with longevity in mind.
    you think new builds are poor new? come back in 60 years.
    • Like Like x 2
  10. Sponsored Links
  11. jacko555
    jacko555
    5 Feb 2005
    146
    Thanks Received:
    17
    Country:
    Yeah, the phrases "built by the lowest bidder" with parts sourced from "the most competitive supplier"...
  12. fillyboy
    fillyboy
    2 Jul 2019
    3,773
    Thanks Received:
    302
    cornwall
    Country:
    I saw a programme some years back about architecture it mentioned art deco buildings of the 30's, a lot of flat concrete roof, slab sides etc, and they didn't last as long as you would expect because of erosion from wind and rain. Water run off and wind deflection are key and the Victorians seemed to have all this nailed.
    Underfloor ventilation to keep the lower walls dry. The ornamental ridge tiles weren't purely for decoration, the scrolls and holes in the ridges broke down wind flow.
    Very clever them victorians, I doubt any modern windows in upvc will outlast a victorian sash.
    • Like Like x 1
  13. ^woody^
    ^woody^
    3 Sep 2006
    29,331
    Thanks Received:
    3,788
    West Mids
    Country:
    A non exposed piece of osb will last forever
  14. freddiemercurystwin
    freddiemercurystwin
    21 Jan 2007
    18,802
    Thanks Received:
    2,082
    Devon
    Country:
    I bought a new house once, in 2000, in the decade I was there I replaced some fence posts and an extractor fan, not bad for a decade.
  15. EddieM
    EddieM
    15 Feb 2009
    9,366
    Thanks Received:
    539
    Country:
    Bet you £1m it won't!
  16. Astra99
    Astra99
    1 Feb 2011
    840
    Thanks Received:
    137
    Gloucestershire
    Country:
    Near where I live, a secondary school built in the late 1960s has, in the last five years been closed and demolished. A junior school built within the last five years has rainwater leaking through the skylights. Compare to the junior school I attended, which was built in the 1890s, and is still being used, although not as a school. Another old school, built in the early 1900s still functions as a junior school! I am sure you can all draw your own conclusions.
  17. fillyboy
    fillyboy
    2 Jul 2019
    3,773
    Thanks Received:
    302
    cornwall
    Country:
    Must've used OSB. :D
Loading...
Share This Page
