No space for a separate mainswitch. Mainswitch is CU incomer. Sub CU needed. Can the one mainswitch incomer on the existing CU also switch the sub CU? That is, one switch does the two CUs. If so, what is the usual way of doing it?
Strictly speaking, as I read them the regs actually require that there be a single switch/isolator controlling any/all CUs in an installation ("single point of isolation for whole installation").... Sub CU needed. Can the one mainswitch incomer on the existing CU also switch the sub CU? That is, one switch does the two CUs.
Eh? No "type tested CU" is fed with a supply which has upstream protection from anything other than the DNO's service fuse. How does feeding it "from a bus bar" differ from feeding it directly from meter tails?Remember a CU is a type tested unit, so unless the manufacturer gives a provision to connect direct to bus bar without a MCB your not allowed to do it, keeping the type tested status.
I've personally never heard of that one. As far as I'm aware, the main difference between a 'type-tested CU' and a 'non-type-tested' DB seems to be in relation to the required current ratings (e.g. 6, 10 or 16 kA) of protective devices - although I've never understood why that requirement should differ according to whether the person 'in control of it' is, or is not, an "ordinary person"!!... However since that job I have been told any premises under the control of an ordinary person should use all type tested equipment ...
Yes, I realise that, but I still don't really understand your point.Bus bar I was talking about was the one inside the consumer unit which connects the RCD or Isolator to the MCB or RCBO not external ...
Can you show us some photos of your layout, please.No space for a separate mainswitch. Mainswitch is CU incomer. Sub CU needed. Can the one mainswitch incomer on the existing CU also switch the sub CU? That is, one switch does the two CUs. If so, what is the usual way of doing it?
I find it rather difficult to believe that something (electrical) which was fully BS7671-compliant could be rendered 'unlawful' by whatever any 'HSE rules' might say.... BS7671 rules are easy we have the book, but HSE rules are not so easy...
Found out, that there are stackable CUs, using only one mainswitch incomer - Proetus is one maker. This is a Wylex CU. I am not sure if Wylex do stackable CUs.Strictly speaking, as I read them the regs actually require that there be a single switch/isolator controlling any/all CUs in an installation ("single point of isolation for whole installation").
However, I imagine that would most commonly be achieved by an external isolator feeding the two (or more) CUs, rather than by using one of the CU's main switches to feed the other - but, even if the latter were done, I would personally still want a main switch in the 'sub-CU', so that it (just it) could be 'locally isolated'.
No need. Just one CU with no space either side and only space below that can just accommodate one CU. I have found it is acceptable, but how will it be done? I know the bus on the existing (master CU) can be drilled with the Line tail to the sub CU having a crimped lug with it bolted to the bus bar. But is there a sort of kit for for it?Can you show us some photos of your layout, please.
No need.
Indeed. I think most of the mainstream manufacturers do stackable ones (although, since they are uncommon, one doesn't often see them advertised by retailers/wholesalers) - and, as I said, there is then a BS7671 requirement that there is only one main switch.Found out, that there are stackable CUs, using only one mainswitch incomer - Proetus is one maker. This is a Wylex CU. I am not sure if Wylex do stackable CUs.
The 18th is a part of the Building Regs which are law (criminal law). BS are recommendations. BS are only law when a part of the 18th points to a BS number as being a part of the regs.I find it rather difficult to believe that something (electrical) which was fully BS7671-compliant could be rendered 'unlawful' by whatever any 'HSE rules' might say.
Kind Regards, John
The stackables only use one Mainswitch in the master CU.Indeed. I think most of the mainstream manufacturers do stackable ones (although, since they are uncommon, one doesn't often see them advertised by retailers/wholesalers) - and, as I said, there is then a BS7671 requirement that there is only one main switch.
