- Joined
- 17 Aug 2010
- Messages
- 2,741
- Reaction score
- 453
- Country
Not really...The 18th is a part of the Building Regs which are law (criminal law).
What onn earth are you talking about?!The 18th is a part of the Building Regs which are law (criminal law). BS are recommendations. BS are only law when a part of the 18th points to a BS number as being a part of the regs.
elaborate.Not really...
That's what I said - and also that, if they had two, tey would be non-compliant with BS7671.The stackables only use one Mainswitch in the master CU.
You may well be able to put the additional conductors into the load terminals of the main switch, particularly if there is only one (or no) RCDsThe only way I can see a non-stackable CU having a sub CU is drilling the bus bar on the master CU after the mainswitch. Other views welcome.
Again, rubbish. See my recent post explaining the relationship between BS7671 (aka 'The Wiring Regs') and Part P of the Building Regs (the only bit of 'law' involved).Electrical regs are a part of the Building regs. Wandering off topic here.
BS7671 is mentioned as one way to satisfy the requirements but not mandated.elaborate.
Indeed so. As I wrote (somewhat less succinctly ) ...BS7671 is mentioned as one way to satisfy the requirements but not mandated.
.... The only relevant law in Part P of the Building Regulations, and that is just one sentence. Many/most people use compliance with BS7671 as a means of demonstrating compliance with the law (Part P), but that is their choice, not mandatory or 'law'.
So a bus bar lug and a lug for the L tail to the sub CU into the mainswitch incomer. The L tail wire has a lug or a soldered end.That's what I said - and also that, if they had two, tey would be non-compliant with BS7671.
As I said, the L conductor might fit into the main switch terminal, without the need for any 'lugs'.So a bus bar lug and a lug for the L tail to the sub CU into the mainswitch incomer. The L tail wire has a lug or a soldered end.
Very true, but what has the EAWR got to do with anything we're talking about?BS 7671 Requirements for electrical installations. is non-statutory. The Electricity at Work Regulations (EWR) 1989. is statutory.
Legal I am am sure. Frowned up.As I said, the L conductor might fit into the main switch terminal, without the need for any 'lugs'.
Nothing.Very true, but what has the EAWR got to do with anything we're talking about?
If you believe that, you would have to 'frown upon' almost all 'high integrity' CUs - which generally have two conductors (one to feed each RCD) plus a busbar (to feed non-RCD circuits) in the load terminal of the main switch.Legal I am am sure. Frowned up.
