I have to replace 3 external wall lights on the front of my house. They look like they were Cheapies from one of the Sheds and are starting to corrode. They are fitted on the wall right up under the Soffit ( Single storey house ) and operated by a PIR at the front door location, with the main switch just inside the front door. From what I can see there is a 1.5mm T&E running the length of the house behind the Soffit and the feeds for the lights have been taken from this, coming through the soffit to the lights. The junctions for these feeds appears to be only done with terminal blocks that have then been taped up and then pushed back up through a hole in the soffit.
Although these terminal block Junctions are in a dry location under the soffit board, I'm guessing that this is probably not the best way to make the connections for the lights. Is it acceptable ( within regs ) just to use a standard chock bock for these junctions, and then maybe tape that up, or is there a better way, bearing in mind that there is a limited space to push any king of connection back through the soffit board. Any advice would be appreciated
