SUNVIC DUOFLOW ACTUATOR
  • Thread starter Thread starter OJ
  • Start date Start date
OJ
10 Nov 2007
Hampshire
Hi - have tried replacing a dead DM4601 with a new DM5601. Wired it all the same, but it doesn't work - it sits in the three quarter way round position, and doesn't move when I change from HW to RADS, etc.
Any advice?
It's not a trick question, guys - is no-one able to offer advice?
What about 'maybe there was nothing wrong with the 1st one' and the fault lies somewhere else. Can you use a multimeter?
Sunvic make two types of actuators. One is MOMO and other spring return.
Looked at Sunvic product list, do not see you model.
this is the list from Sunvic can't see the numbers your quoting?
2 Port Selection Guide
Complete
Actuator &
Valve Order
Code Actuator only
order code 2 Port Spring
return MoMo 4 Wire Actuator
normally
closed Auxiliary
switch S.P.S.T.
normally
closed Thumb-Wheel Flushing
Lever Valve
Body
only
order
code 15
mm 22
mm 28
mm 1/2"
BSP 3/4"
BSP 1"
BSP External
compression Female
SZ2201 ● ● ● ml3402 ● ●
SZ2302 ● ● ● ● eml3454 ● ●
SZ2351 ● ● ● ● eml3503 ● ●
SZ2301F ● ● ● ● ● ● ml3401 ● ●
SM5201 ● ● ml3451 ● ●
SM5203 ● ● ml3501 ● ●
SM5205 ● ●
SMV2217 SM5203 ● ● eml3454 ● ●
Any of the above SM/SZ actuators can be used with any of the ml/eml series of valves
SZV2286 SZ2301 ● ● ● ● ● ● ml3402 ● ●
SZV2212 SZ2301 ● ● ● ● ● ● eml3454 ● ●
SZV2228 SZ2301 ● ● ● ● ● ● eml3503 ● ●
SZV2288 SZ2301 ● ● ● ● ● ● ml3401 ● ●
SZV2289 SZ2301 ● ● ● ● ● ● ml3451 ● ●
SZV2218 SZ2301 ● ● ● ● ● ● ml3501 ● ●
SZMV2322 SZM1801 ● ● ● ● ● ml4402 ●
SZMV2305 SZM1801 ● ● ● ● ● eml4201 ● ●
SZMV2323 SZM1801 ● ● ● ● ● eml4503 ● ●
SZMV2324 SZM1801 ● ● ● ● ● ml4401 ● ●
SZMV2325 SZM1801 ● ● ● ● ● ml4451 ● ●
SZMV2326 SZM1801 ● ● ● ● ● ml4501 ● ●
3 Port Selection Guide
Complete
Actuator &
Valve order
code Actuator
only
order
code 3
Port Spring
return MoMo Diverter Mid-Position 2
Wire 4
Wire Auxiliary
switch
Thumb-wheel Flushing
Lever Valve
Body
only
order
code 15
mm 22
mm 28
mm 1/2"
BSP 3/4"
BSP 1"
BSP External
compression Female
SDMV230 SDM1901 ● ● ● ● ● ● edt3201 ● ●
SDMV232 SDM1901 ● ● ● ● ● ● edt3706 ● ●
SDMV232 SDM1901 ● ● ● ● ● ● edt3606 ● ●
SDV2211 SD2701 ● ● ● ● ● ● edt2702 ● ●
SDV2291 SD2601 ● ● ● ● ● ● edt2702 ● ●
SDV2294 SD2701 ● ● ● ● ● ● edt2706 ● ●
SDV2295 SD2601 ● ● ● ● ● ● edt2706 ● ●
SDV2296 SD2701 ● ● ● ● ● ● edt2606 ● ●
SDV2297 SD2601 ● ● ● ● ● ● edt2606 ● ●
SD2751 ● ● ● ● ● ● edt2702 ● ●
dt2606 ● ●
dt2601 ● ●
Any of the above sd actuators can be used with any of the dt/edt valves
The Duoflow system used to have a grey metal control box. If it's got this it's more than likely going to be the relay inside that has gone.
It might be easier to remove the Duoflow control box, fit a normal mid pos valve and wire up as y plan.
regards
Hi DP,
In my experience it's the relay in the Duoflow control box that plays up.
I think microswitch's must have just been a dream in those days.
rgds
there's a big grey metal control box with a relay inside controlled by the room stat, think I would sugest change to a y plan, not sure if you can still get a acutator for this thing.
Wetshoes i thought you were refering to the actuator.
OP, if you have spring return actuator instead of MOMC, terminate orange wire to 10 (or 14 if you choose), grey to 11 and white to 1 on the grey box. If relay is removeable, remove it else remove wire from 1 and connect it to white from MV using a choco block. Blue from MV goes to 16
You must be electrically competent, ELSE LEAVE IT ALONE.
The actuator doesn't have a microswitch on these.
Control box does it all
Although it's possible to wire around the relay when fitting a 3 way valve (with microswitch) in my experience once the relay goes the pcb in the control box will follow it shortly, after all they have to be at least _oops showing my age now_ years old.
Surely not much more wiring involved to get rid of control box and replace with nice shiny plastic wiring centre that most plumbers / electricians will understand and be able to work on.
Wethoes, does the actuator not have contacts to control positioning of actuator drive??
