- Joined
- 22 Oct 2007
- Messages
- 130
- Reaction score
- 0
- Country
First things first, I have searched for this and am unable to find the answer!
In my bathroom I have pull switch, light fitting, radiator and bath. I believe I should bond between pull switch, bath and radiator?
My radiator pipes go into the concrete floor and do not reappear until 5 metres away on the other side of my kitchen, should I chase out the bathroom wall from ceiling to floor to run the earth to the rad or can I run the supplementary bonding back through the kitchen ceiling and connect to the CH pipes feeding the bathroom under a wooden floor? The bath is opposite the radiator with no easy path to bond directly between them.
Also, can I bond bath and radiator via the light fitting or should it go back to the pull switch? Or should all four points be bonded?
Thanks for any help
Edit: My pull switch is outside the various zones (just) so I assume I can bond the other stuff via the light fitting?
Thanks for any help
