Supply lighting circuit via fused spur on ring
4 Nov 2007
Is it permissable to feed a lighting circuit from a ring mains via a fused spur?
If so what must be put in place to allow this etc.
11 Jan 2004
Yes.
A fused spur!
If possible, wire the fused spur into the ring final circuit. Then on the load side of the spur, use a fuse suited to the total load and choose the cable accordingly.
If you want, you can use a switched spur to switch the lighting direct from that switch or you could use a an unswitched fused spur to feed the lighting via a plateswitch.
4 Nov 2007
I am sorry for my impoliteness, thnx guys for the help, it is much appreciated
E
EdwardCurrent
Can I just ask if the circuit that you are 'picking' these lights up from is RCD protected ?
Regards
Ed
4 Nov 2007
it is rcd, 30mA protected, thnx
Regards
Ed[/quote]
2 Jun 2005
Cumbria
It is imo a poor setup to have lighting circuits spured from a ring circuit. It is OK for say a couple of fluorescents for say under unit lighting but I'd edge away for using it for a full circuit.
It is better to have them from the consumer unit so the installation is divided into circuits to avoid inconvenience.
4 Nov 2007
I would agree but the floor is blockboards and its only to feed 2 lights in a new extension
