Hi, im new to the board.
I live in a 1st floor flat and my consumer unit is in my hallway. The meter and isolator are located on the ground floor in a utility room. It is a 106 year old building converted to flats and im guessing the installation is 30+ years old.
Currently the supply from the meter to my consumer unit is via 12m of 2 core 10mm steel wired armour cable feeding a re-wirable wylex board. The cable goes up through the utility room roof (which is below the stairs), clipped to the communal staircase wall and disappears through the wall into my floor space where it reappears and goes up the wall to my CU.
I am re-wiring the entire flat and will be fitting a 17th edition board. Im up to date with 17th edition and have 2391 but just not with a trade organization (hope to use this for entry).
What should i use for the 'tails' as it were? Is SWA acceptable between the meter and CU and at that length? I haven't come across an instalation like this before so would apprieciate some advice.
Thanks for you time!
Matt
Matt
