How do we check if the wall is load-bearing - does it matter?
Yes, definitely matters!
Here are some things you can check:
1: Tap the wall and see if it sounds hollow. If it does it's likely to be timber (or metal) stud. This alone doesn't confirm it's non-loadbearing, but stud walls are less likely to be load bearing.
2: Go upstairs and check which way the floorboards are spanning (if possible). If the floorboards are running parallel to the wall then the floor joists must be running perpendicular. This still doesn't 100% confirm that the wall is load bearing (depending on the location of the wall), but it makes it much more likely that it's a load bearing wall. Likewise, if the floorboards run perpendicular to the wall, the joists must run parallel, proving the wall doesn't take floor load (you need to do this check on both sides of the wall as it might be taking load from one side only).
3: Check if any walls upstairs line up with the wall below. If they do (and are not supported by a trimmer joist (or sometimes off the floorboards itself in older houses), the wall is load bearing.
4: If there is a wall directly above, and you can't confirm what's supporting it, check in the attic. If any struts or purlins are supported by the wall at first floor then it is definitely load bearing. This still doesn't 100% prove that the wall at ground floor level is load bearing though (Maybe there's a steel beam above it).
5: Check if the stairs are anywhere near the wall. The floor might not span onto the wall but it's still possible that a stair trimmer does.
These are the checks that I would do on a site visit. This would satisfy me for the purpose of design as to whether or not to design a beam or perhaps give the go ahead to remove the wall. However, my design would likely be caveated by a note saying, "Opening up works to be carried out on site to confirm assumptions".
The opening up works would be as follows:
6: Knock some holes into the ceiling at the junction with the wall. If you couldn't see the floorboard spans, you will now be able to see which way the joists are spanning.
a: Are the joists perpendicular to the wall?
b: Does the wall continue up?
c: Does the wall support a stair trimmer?
If you have answered no to all of the above I'd be comfortable saying the wall isn't load bearing.
d: Are the joists perpendicular to the wall and do they end there?
Wall IS load bearing
e: Are the joists perpendicular to the wall but continuous over it?
Wall MAY be load bearing. Get an engineer to check if the joists still work with the wall removed.
f: Does the wall continue up?
g: Does a stair trimmer (or other trimmer) bear onto the wall?
Wall is PARTIALLY load bearing. You may be able to remove part of the wall, or have a trimmer / beam designed and remove all of it. Consult an engineer.
Then there is the buttressing issue. Up to 6m between buttresses shouldn't be an issue so if the distance between buttressing walls (once the wall in question is removed) is 6m or less, no problem. If more, consult an engineer.
The other issue to consider is what any beam will bear onto (if one is needed). Is there enough wall left either side to allow sufficient bearings for the new beam / pad stone. A very slender section of remaining wall may not be suitable to support a new beam.
That's the best advice I can give. Do you trust your hubby enough to make the right decisions, or would you rather consult an engineer to confirm things for you?
Good luck!
