Window into new Entrance Door
20 Jun 2006
Cumbria
I'm planning to open up an existing window into a new main doorway (interior to exterior).
Other work in the house mean that I'm loosing my existing front door so I want to make a new one into my sittingroom. I think that one of the windows in the sittingroom was once a doorway (old neighbours say it was and the wall is thin and newer there - there's also built in book case beneath the window).
Here are the facts:
It's an old house - 1800? built of local stone and lime and mortar.
There's an old (supporting) beam sitting immediately next to the window lintel.
Can I just trust that the lintel above the window will be fine if I'm just removing the window beneath? The window frame is pretty small 50mm x50 each side - do they ever carry load?
If I take out the (newer) brick wall beneath the window, is there any danger of the old walls eitherside sagging into the door space - ie: could this newer wall be bracing the old sides?
Any help or experience anecdotes are very welcome!
Thanks!
(see my post on "Porch" for the porch I plan to put over the doorway).
As long as you are not making the opening any wider it should be fine, but condition of the existing lintel should be check, you may find there isnt one - in which case it may need replacing.
