A friend has just bought a 3 bed semi for just under £300,000 and the surveyors report mentioned the porch roof and a few suspect tiles on the pitched roof where an old solar power system had been removed. That was all that was mentioned as needing further inspection.
Once the deal had gone through I went to help him move in and the CU has a few blanking plates missing and there is a length of 2.5 t + e running out of the cu into a switch then outside and in a few lengths of overflow pipe (not connected to each other so hanging on the wire where they've separated) down the garden into the garage. Probably a 50 metre run.
I've suggested getting a split load board fitted and replacing the t + e with swa.
Is this something the surveyor should have picked up on? and is there anything he can do to recover his expenses with the surveyor if can be proven that they have not satisfactorily carried out their duties?
Thanks in advance,
Kev
Thanks in advance,
Kev
