I am trying to fit the above in a Victorian style upvc conservatory.
The area is just under 10m2 ie 3.435m x 2.840m.
The shorter figure is the wall that has the front corners cut off if you know what I mean ie the victorian bit.
I have obtained all the bits to build and hang the grid plus the tiles from Minster, using their grid calculator for 10m2 I have
3 main runners @ 3700mm, 14 cross tee @1200mm, 14 cross tee@600mm,
perimeter trim, 28 600x600 tiles + hanger brackets and wire.
I have fitted the perimeter trim without too much trouble, what I cannot get my head around is wear I place the 1200 cross tee and then the 600 tee.
I thought I would run the three main runners on the 2.8 length to make it easier to fit the tiles around the victorian bit.
If anyone has access to the Minster calculator book its page 75 usg grid calculator.
I am pulling my hair out and getting no where.
Please help an oap.
Please help an oap.
