Hi wanted extend the cable on 1of my camera ,bought more cable from mapling and joiner, plug i
T in but don't get picture, there is power getting to camera tho ,any ideas
Firstly before extending the cable can you get a picture?
If yes then the issue could be your extension, how long is your extension and is it following the manufacturers specification as some devices cant be extended or can only be extended to a maximum length.
I would check you can get your picture first without the extension, then check your cabling.
