As suggested, I would recommend the distance from the wall is changed anyway, for me it is too tight to the wall as it is, there really should be a gap down the back of the rad for air flow. Coupled with the thicker rad then it would be coming out further, unless that's not an option?
Thanks would you recommend 10mm spacing from the back of the radiator to the paneling? I can achieve this by spacing the clips off the way abit when fitting the new rad.
