That will be Switched Live and Neutral - otherwise you wouldn't be able to turn it off.I currently have just a permanent live and Neutral wires available.
Ok.I'm not fussed about the timer function.
That should be ok.I tried placing a wire loop between the LS and L but this didn't work. Any suggestions?
Doesn't matter as long as it is connected to both.Just wanted to check, my Switched Live goes to the LS on the fan? not the L on the fan
Could be - but could still be 240V if, as I meant, you have blown something in the fan.Ok will get a multimeter tonight and check. Thanks for the help.
If i have blown something then i presume the reading would be zero between L and N?
