Switch problems
14 Mar 2005
I'm replacing all of the switches in my living room. Can anyone help with a couple of problems:-
1. If the terminals on the new socket are marked COM, 1 Way and 2 Way, do you wire the live to the com terminal, and the neutral to the 1 way terminal?
2. I have a switch that has two switches on it as it used to feed a spotlight in the ceiling. As the spotlight has been removed I want to replace the switch with a single switch. It is wired as follows:
Live to A2 with a connection from this terminal to B
Blue wire to A
Yellow wire to B2.
How would I connect it to a single dimmer switch.
3. Can any light be connected to a dimmer switch.
I have a double switch which I want to connect to a dimmer switch which is marked
Live, Switch and earth and there are 2 seperate sets of terminals so marked.
As I had 2 sets of wires on the original switch I thought that it would be a simple case of wiring each set to the live and switch terminals but when I did each set of lights would not turn off.
Can anyone help a dimbo please.
Possibly
Be careful, there is not usually a neutral at the switch. If it is a neutral then when you pressed the switch a short circuit would be created and trip the mcb in the cu.
Blue wire to A
Yellow wire to B2.
Remove the link from A2 to B. Put the yellow in a connector block. (Assuming the yellow went to the spotlight that has been removed. Otherwise Put the blue in a connector block)
No. The instuctions that came with the switch will tell you.
You have it wired incorrectly. Which terminals did the original wires enter?
Not a problem
i would like to add, just becuse its black, doent mean its neutral, at a switch is most likely to be swithed live, which also means at the ceiling rose it will be black.
may i suggest you look in for reference then you will see how it is done. Also get a multi meter, you would expect a mechanic to fix a car with out tools would you?
Re Question 3 and the request for "which terminals the wires entered:
The wiring in the original switch was:
Switch wire to A COM
Live wire to A 1 Way
and
a Switch wire to B Com
Live to B 1 Way.
Thanks for your patience
There is your problem!. Live to A com and switch wire to A 1 way. live to B com and switch wire to B com will rectify it
