synchron motor fitted, now boiler not workin!
6 Aug 2009
Lancashire
fitted a new synchron today and all was ok, ch wasnt comin on when i demanded hot water. around an hour after i went to put hot water on and the boiler will not fire up now. dont know if this is because of the work that was done or not or just bad timing as for a couple days now the boiler is firing up as normal then after 5 min will reignite itself and also try ignitin whilst the boiler is actually burnin! anyway the pump is running and continues to run without switchin off, the pump is new and was fitted around 2 month back
boiler is a glow worm ultimate 30ff
pump is a grundfos selector
hope this is enough info and thanks for ur help
grundfoss pump is spinning fine, i switched the mains off for about an hour then back on, created a demand and it fired up for around a minute. the 1st neon light on pcb is now showin but nothing else. the pump is still runnin... had a look at booklet and i am leaning towards pcb or overheat device??? please help!
oh ok thank u, i had the exact same problem a couple month ago and had a diagnostic come round who said it was the pump, the pump was replaced and was all ok. this time it defo isnt the pump as its spinning fine. can it be a fault with the synchron put on today or is that not possible?
