- Joined
- 1 Dec 2021
- Messages
- 1,904
- Reaction score
- 292
- Country
That sort of makes sense, just how would the heating not come on when the hw is called?
I think I have some space for a manifold on each floor, the problem would be running so many pipes around the house in timber floors. I assume main feed and return to manifold in 22mm and each radiator comes off in 15mm?
can 2 or more radiators come off a zone on the manifold?
I have 12 rads split between 2 floors and serviced by 4 manifolds (two supply, two feed).
My system is 2000's and std practice for new builds.
The boiler just heats up the supply circuit. The rads and tank take a feed of that as and when required by asking the controller to fire up the boiler and opening the line valve (either on the rad, or on the hw tank feed).
The system only takes what it needs.
The old s plans etc, were a macro approach to heating as smart rad valves were not a thing. All you could do in a zone was limit temps by setting the trvs.
Tech has moved on. S plans, etc are, imho, dead tech, certainly so for new installs.
My opinion anyways. Others here might disagree.
