- Joined
- 12 Feb 2017
- Messages
- 93
- Reaction score
- 1
- Country
I've got a traditional central heating system with a 3 port valve, Y plan wiring, room stat, tank stat, and a Bosch Greenstar cdi classic boiler. I've noticed the boiler seems to be running a lot of the time, We've also got a frost stat setup(room and return pipe stat fitting into an outhouse with the boiler) to prevent freezing. I've just popped open the front cover of the boiler and noticed there are lots of connection to the boiler, not just live, neutral and earth, and a switch live. I was always under the impression you linked out the live and switch live on the boiler and let the external controls handle switching the boiler on and off, but with more modern boilers do they need some control of the system components and feed back from the temperature sensors so alter flow and return temps. Does the boiler just measure the return temp and switch off when the returning water gets to hot? or when the external controls say there is no call for heating?
