SYSTEM LOSING PRESSURE BUT CANNOT FIND LEAK
3 Nov 2009
Essex
Please help!!!
I'm about to put my flat on the market but the heating system keeps losing pressure. It definatly does not have a leak anywhere.
I have underfloor heating on two rooms from a manifold, and 5 radiators.
I have an expansion vessell and a Potterton Profile boiler with a storage tank.
The pressure releif valve from the boiler does not exit an outer wall, I think it has been plumbed into the waste somewhere as the previous owner was a plumber and I can't ask him about it because unfortunatly he is dead. I spoke to a plumber last week on a job I was on about this and he advised me to pressure the system and see if air or water comes out of the bottom of the expansion vessell, I tried to today when I was there and got air.
Any other suggestion please, or any good plumbers near N11???
Mark
15 Feb 2008
Manchester
Trace the PRV pipe work disconect it and put a plastic bag over it with an elastic band to hold it in place repressurise the system then as the pressure drops check it.
3 Nov 2009
Essex
Thanks for reply mate but I have tried looking for the prv pipework and suspect it may have been chased into the wall behind the tiling. I have had the plastic cover off the bottom of the boiler but cannot see any pipework branching off anywhere.
3 Nov 2009
Essex
Sorry to sound like a complete idiot but disconnect what from where?
Not too knowledgeable about boilers
9 Dec 2009
Lancashire
have some one look at your boiler it may cheap in long run
but the prv goes outside via a piece of copper
27 Sep 2010
Does the pressure gauge go up significantly when the system is hot?
2 Dec 2005
From my boiler having same probs a year ago, Pressure raises when heat on, Over night or when not on for a length of time pressure drops off scale..It was my expansion vesal in the back of the boiler..Pumped it up and all was fine
