- Joined
- 1 Dec 2021
- Messages
- 1,906
- Reaction score
- 296
- Country
Why fit a sealed system with a system boiler? is the question.What are the pros for open vented in this case ?
Unless you are living in a flat, i can't see an obvious answer.
Considering this myself atm because of air in the system.1. You can have a sealed system on an open vented boiler, provided the boiler MI's says its OK. Most do.
2. On the sealed v. open vented debate, I prefer sealed. Because:
2.1 The only extra things to go wrong in the long run are the expansion vessel and pressure gauge. In my opinion this outweighs the chances of air causing corrosion if the inhibitor is not maintained.
2.2 You can get rid of the F&E tank, and its normal collection of nasty gunk waiting to be washed into the pipework.
So from my POV it wouldn't matter.
X plan?Say heating at 50 to maximize condensing and HW at 55
X plan?
I have a feeling the "cool radiator" idea maybe suspect.Say heating at 50 to maximize condensing and HW at 55
No, brand new system, so we can do what we like. Will ask if the Worcester Regular Boiler can automatically put out top heat if there is a large difference between thermostat and ambient, or if hot water is needed. Or maybe it does it on the difference in temperature between flow and return. Will send them an email now.Is this a replacement boiler for an older system?
The best way to heat a room is with a very hot convection radiator because air flow depends on the radiator being very, very hot. Unless you use a fan to help with air flow, which is what I have read Daikin have done for their "cool" radiators (Daikin Altherma HPC).I think the science behind condensing is sound - in theory.
There are some quite good articles on the efficiency falicy of condensing boilers. I went down that rabbit hole a few years ago but quickly came to the conclusion that replacing my std non condensing boiler for efficiency savings would never recoup the payback.No, brand new system, so we can do what we like. Will ask if the Worcester Regular Boiler can automatically put out top heat if there is a large difference between thermostat and ambient, or if hot water is needed. Or maybe it does it on the difference in temperature between flow and return. Will send them an email now.
While it may be "cheaper" to run the boiler at 50C, it is not cheaper if it has to run for longer, and the inconvenience for waiting until the rooms have reached temperature. Is my thinking.
What's the term, SEB?I think of the condensing gains as a potential cherry on the top. The bigger gains come from other efficiency improvements. A brand new boiler is 20% more efficient than a 35 year old boiler, even if it never condenses at all.
