Good morning all
I’ve been searching your forum but haven’t found anything like my problem.
I have just bought the following:
Honeywell Accenta Mini with LCD remote keypad. (8SP399A-UK)
ADE Reson8 bell box.
3 x Honeywell IS312 PIR motion sensors.
To make life easier I decided to put the system together on the table before installing it.
Unfortunately I get a recurring ‘system failure ‘ fault.
I suspected that I have wired up the sensors the wrong way but have tried various combinations with same result although occasionally the system does say something like ‘system setting’ but unfortunately it just beeps very quickly and never actually set. The interesting thing though is if I put my hand in front of the sensor at this time the alarm sounds.
Description of recurring fault.
I currently have the 3 sensors wired into zone 1,2,3, the PA has a link in it.
I put power to alarm- it shows date and Bell sounds -insert code - then shows 12345678 TP with zeros below the numbers- it then says ‘user restore press X’ then shows -System unset
All seems good so far.
I then insert code to set alarm.
It now shows ‘System Fault 4 kitchen’ but there isn’t anything connected to zone 4.
I removed zone 1 wires and put them in zone 4 but it then said ‘System fault 1 Hall’ and likewise when I swapped the other zones about. It seems to always fault on a zone that isn’t wired..
My sensors have terminals as follows ‘+ - N NC T1 T2’ I’ve interpreted T1 & T2 as tamper ( but not sure) and wired the C & NC to the zones in panel.
Unfortunately Honeywell don’t have any help unless you are a professional installer which isn’t very helpful.
Thank you for reading
