while I have the living room floor up and have added in some extra sockets on my ring main (which only serves that room) I would like to install a table lamp circuit - we use table lamps for low level lighting and I would like to be able to switch them all on and off at a single switch.
So ive got some (2A rated) small round pin sockets and plugs (5 of each) and have run a circuit of 1.0mm2 cable between them
To avoid having to take this back to the RCD as a new circuit, can I feed this table lamp circuit off a fused spur off the ring main? I would put a 2A fuse in the switched fuse unit. Of course the spur to the fuse unit would be 2.5mm2
1) is this acceptable under the regs
2) is it ok to wire both ends of the table lamp circuit into the 'load' terminals in the switched fuse unit - so the power can flow either way ie acting a circuit, but fed by a spur?
I have added up the current likely to be drawn form the lamps I intend to plug in, at 0.3 amps I figure the 2A fuse and rating on the plus/sockets should be ok.
any advice/corrections would be much appreciated - new to the forum: so sorry this is long. I have a reasonable amount of experience of adding in new sockets, extending lighting circuits (understanding the loading issues), but never go anywhere near the RCD unit - if I cant add something in to an existing circuit then its off bounds as far as im concerned.
