- Joined
- 6 Mar 2018
- Messages
- 17
- Reaction score
- 0
- Country
Good Afternoon,
My heating system has a taconova setter fitted before a heat exchanger with pump. I've noticed that the spring inside the setter seems to be moving around a lot while the pump is running, is this correct? I don't think it did it before. The pump has recently been changed though. So I'm wondering if this is a)normal or b) the flow rate is now to much or to little for the pump. The internal baffle never changes position even when the flow rate is changed.
http://www.taconova.com/en/products/pv/-/-/tacosetter-inline/11/
