Tado Smart Radiator Valve Installation
6 Sep 2007
Birmingham
Considering buying the Tado Smart Thermostat and valves. However I'm not sure if my upstairs radiators will be compatible with the valves. Has anyone had any experience of installing Tado Smart Valves. Do you know how to determine if they'll fit?
Those aren’t compatible, you’d need to upgrade to normal TRV’s with threads and then the Tado heads.
Those are the adapters you get with the tado trv, hopefully someone can advise if there's a suitable one there.
All big thanks for your help and Thom1983 thanks for the images. Looks like there's lots of options. I think the best bet is to buy a set and put them on my downstairs radiators and then try one of them on the radiator upstairs.
Got DANFOSS RAS-D² ANGLED THERMOSTATIC TRV & LOCKSHIELD 10/15MM X 1/2
Do you know how to remove the thermostat?
If you want a set of adapters to try I'll send you a set of mine, all my rads use the standard fitting with no adapters so I've bags full of them that will get binned eventually
@thomp1983 huge thank you for the offer but going to buy the valves. Was just busy buying the wireless kit which I’ll have a try at fitting. Thanks again for the offer.
Hi @griffen I would to do the same thing - i.e. connect the same DANFOSS valve to a Tado thermostat. Did you manage to find an adaptor and could you send me the details? If so, have there been any complications? Many thanks!
