Tag reader
15 Jun 2022
I have down stairs night set (b)
It's sets fine. When I activate it by the hall pir it sounds but my fob doesn't switch it off.
The hall is set to 09 ER (area fx)
What am I doing wrong?
Either your user (the fob) isn’t set to manage area B or you’ve not selected area b to be unset when the button gets pushed
Not a button its a tag.
The tag is set to am and unset abcd.
I set b from the app
Sorry you’re confusing me. You spoke about a tag and then fob in the same post so I assumed you had both and were setting with one but having problems unsetting with the other
Now you’re talking about having set it with the app?
Please explain what you’re actually doing, trying to do, and not managing to do
Sorry full set is ok. Part set B is down stairs. I set on the app B. I have a tag reader at the bottom of the stairs. The first pir to see me is the hall. Opposite the tag reader. I present the tag and it does not unset the system. Pir set to 09 ER ( area FX) now something else has happened when I walk past the hall pir it doesn't light up but it does in the walk test.
Yes but it's decided to show its light now. Its mind boggling.
Thanks sparky for your help
Can you try and set area b from the panel and once it’s set see if your tag will unset it when presented at the panel, not the tag reader
Wireless pirs don’t light up all the time …they go to sleep that’s why it lights up in walk test , it will be awake when you arm the system …
Thanks for the comment.
As soon as I am downstairs it picks me up and beeps.
When I present the tag the system does not unset B but tries to Full set A.
I think I must be missing a setting somewhere.
Just a thought, I am aiming B with the app and trying to unset with the tag.
Does this make a difference
I have armed A with app and unset with tag reader successfully so it's down to a setting somewhere. Any ideas?
Ok …. In keypads what address is the tag reader ? 01 ? Look at what it says for this
Type …reader
Set point sets ABCD
set point UNSETS ! should be ABCD
if not add the B ect
