Ok, before I get beset by lots of posts saying it's external work, it's regulated by Part P... you can't do any of this yourself... etc... let me first comment that a) I am very aware of Part P, and b) I have no intention of doing the final connections at each end - I'll be getting a qualified sparky in to do this - I am aware however that I can for example dig the trench as it's fairly pointless to pay for this!
Ok with that said here's the situation:
My wife would life to have electricity taken out to the front garden to provide sufficient power to drive a water feature (small pump circa 80 watts - she doesn't want a solar powered one) and some low wattage lights (circa 100 Watts) - total of about 10 meters from the house.
I would also like to provide a 13Amp external socket (on the side of the house) for connecting the lawn mower / strimmer.
Ideally I would like to be able to pull cable through conduit (so that should it ever be damaged I don't have to pull up the whole of the front garden again!).
My proposal would be to:
Dig a 'suitably deep' trench to bury the cable - the cable will go partly under a path and then under a raised flower bed. I expect to go about 500mm down under the path and 600mm under the flower bed. I can obviously do this work myself...
I plan to lay straight (trying to bend cable is always a nightmare) PVC 32mm conduit with swept bends through which I can run 4mm SWA (3 core). I (by use of a sparky) would then look to terminate one end of the cable to a suitable ground mounted (min height above ground?) IP66 switch box in the flower bed from which I can switch on the lights / water feature. The other end would run up the side of the house into a junction box that provides an external socket and passes through the wall to a spur off the main house ring main.
Does all of that sound sensible? Is there anything I have overlooked / that you professional sparkys don't like the sound of etc?
Also should I drill out the base of the conduit to allow for drainage?
