tamper lock out
2 Sep 2011
Wolverhampton
optima/accenta tamper lock out . having problems finding the problem have taken out tamper circuits and replaced with links but still no joy , this alarm was working fine until i tryed to a second programme on the remote keypad so as i could do a part set on programme 2 .since doing this with no joy after several attempts the system has gone to tamper lock out and cant get it to work ,have i done somthing by trying to do this second praogramme .tryed turning it all off disconnect battery anbd reconnect with no joy
try linking out T and A on the SAB connections, this might fix it,
if it does,
remove the tamper (global) and try to reset system, if this works, go buy a new bell box!
hope this helps
Oasis
I'm sure I had same problem once. Scott1980 helped me sort it.
