I have a garage which is built with the walls sitting on the concrete slab, with a DPC at floor level, single skin brick. Parts of the walls are below ground, when it rains water seeps through the DPC. I've dug out and exposed one side and will cut back the DPC as close to the brick joint as possible. The plan was to paint the below ground brick and over the dpc with a bitumen emulsion and back fill. However I am unsure on the longevity of this and whether a tanking slurry would perform better? Pros and cons to both? Which would you go for?
![120930287_10158263528353725_7298911078848087894_o.jpg](https://scontent-lht6-1.xx.fbcdn.net/v/t1.0-9/120930287_10158263528353725_7298911078848087894_o.jpg?_nc_cat=103&_nc_sid=0debeb&_nc_ohc=kP8xeIScLcoAX-adqMk&_nc_ht=scontent-lht6-1.xx&oh=d65b244b4d8f68e7151837ef6c15c76a&oe=5FA1E09F)
![121011619_10158263528788725_8366265148596308579_o.jpg](https://scontent-lhr8-1.xx.fbcdn.net/v/t1.0-9/121011619_10158263528788725_8366265148596308579_o.jpg?_nc_cat=102&_nc_sid=0debeb&_nc_ohc=3cnpC4MJ-5IAX8xOu8T&_nc_ht=scontent-lhr8-1.xx&oh=e88ecceba1e69be15c6924736388f6da&oe=5FA1FAFE)
