Tap fitting
26 Jan 2006
Hampshire
Hi I am just fitting a B & Q mixer basin tap and it is supplied with two flexible tails one end of each fits into the tap and the other end has what looks like a normal 15mm tap connection to fit to thepipework.
I can't seem to locate a fitting which this will screw onto at the pipe end.
(That is a male thread on the supply pipe) :shock: :shock:
You either have a compression fitting that you have lost the nuts and olives for or a bush which you need to obtain a fitting for. Take it to a plumbers merchants and let them have a look at it.
I`ll bet some bugger whipped the partsout the bag before swimmer bought it :shock:
Fit two 15mm isolation valves onto the hot and cold feed pipes and remove the end nuts, the flexi's will fit onto the valves. :D
U should go & buy 2 x 15mm by 1/2" bsp straight male iron to copper fittings. these have a flat on one end so the rubber washer in flexi tail isn't damaged. F you prefer to take the other suggestions u can file off the taper when the compression ring would seat to create a flat .
