thanks - but my problem (or my madness! is that this MASTER doesn't seem have a connector block!!!!
You only need three wires pin 4 is not used in domestic situationsELZ4742 said:put the O/W in 2 & W/B in 5 on the left hand side terminals (top and bottom as you look at it from the back
theflyingpig said:Chri5 - thanks - clarity! and a great link!
so you can push both the BT wires, and the wires off to the first extension into the same connectors?
in your opinion would i be better off acquiring a NTE5 and replacing this altogether?
ta
