temporary cheap and cheerful down lighters/ spots
17 Oct 2004
Can I run cheap downlighters/ spots from a 3 pin plug in a wall socket?
Its for a temporary work situation, doesn't have to look pretty and won't be left on unattended.
Can be 240V or low voltage. Is it possible to run such things off a 3 pin plug and if so - which type and how many lights can I have max?
needs to cost the bare minimum....
thanks in advance
should be fine. Use a 3A or 5A fuse depending on rating. Flex sized appropriately to fuse rating.
Make sure all flex is well restrained so it doesn't get pulled out.
ok, thanks for the replies. So I just add up the watts on the bulbs and use the right fuse and cable. :D
Is there any advantage in using 12V as opposed to 240V? I'm not bothered about the running costs ie electric consumption.
