Evening All,
Our shower started smelling, so I've opened it up and found what appears to be a iffy connection to the terminal block as its burnt and so is part of the wiring.
I've stripped back the 6mm cable, removing the bad section but want to replace the terminal block.
Could someone tell me what amp rating terminal block I should be using and where to buy it?
Thanks Scott
Thanks Scott
