Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Doubling the end of the wire over is only needed if the wire is small compared to the size of the terminal.
For example, if you have sockets with very large terminals, and only a single wire going in there, folding the wire over will fill the terminal better, so that the wire is secured properly.
If there are several wires, then not necessary. Don't twist wires together either.
