Terminating stranded cable
11 Jul 2012
Nottinghamshire
What's the best crimp connection to use for terminating stranded cable into the back of a switch ?
I've looked at spade, pin and fork terminals but I'm not sure which is most suitable.
why use a crimp at all?
Just strip it, bend it back on itself so its doubled up and screw down
You can use bootlace ferrules for said purpose but you need a special crimp tool and, whilst it's tidier, it's not strictly necessary
The cable is a power cable from an electric fire, I cut the plug off and want to wire it into an FCU. The strands are extremely fine and break easily, I don't want to bend them back and have them snap, I don't have much cable to play with as it is.
Thanks for the reply.
I googled those ferrules, they look right. Cheers.
You say a special crimp tool, is that something other than standard ratchet crimpers ?
I prefer using ferrules for stranded wire, it's just bodgery screwing down onto strands.
And some with no colour coding at all.
Those aren't non colour coded ferrules, they're un-insulated ferrules.
The colour coded ones are no more insulated than the un-coded ones.
The insulation of the wire insulates as far as the metal of the ferrule.
The plastic part acts as a funnel to assist getting all strands into the metal part and also moves the bending point away from the exposed strands and onto the wire's insulation. This reduces any bending stress on the strands where they enter the ferrule.
The problem with those is that the quality of the crimp depends entirely on the skill and experience of the operator. Poorly made crimp joints can look OK, and even withstand a pull test, but overheat over time, causing a fire risk. That's why ratchet crimpers came into use.
