Terminating SWA...
2 Feb 2004
Which metal boxes should be used for terminating 6mm swa cable and where can you get them? Thanx in advance...
somthing fairly big
if you are using a small metalclad or IP rated plastic CU (i wouldn't adsise it with a standard household pastic one) in the outbuilding you can terminate direct to that
at the house end i tend to prefer an isolator or rcd in a metalclad modular box
if you are just looking to terminate the cable to twin and earth a 6x6 adaptable is probablly the way to go
Thanks! You mean like this?
I assume this box just suitable for indoors. My electrician suggested terminating outside, pulling the inner core inside - I'd need a smaller hole through the wall.
Is this a good idea? What box could I use for outside? Or should I bring the whole cable inside and terminate it indoors?
I usually terminate inside if there is a suitable location and the hole can be drilled without breaching a damp course.
i *strongly* reccomend terminating inside
i also advise entering buildings (especilly wooden outbuildings) through the floor if practical
Thanks guys. I have masonry walls and solid floors so I cannot go in beneath the floor. Was the box in the link OK? Any alternatives?
Tip - drill the hole for the cable angled downwards from inside to out - water doesn't run uphill.
yeah thats the way for a brick building
a hole in brick is pretty easy to seal anyway though
with a thin wooden structure though you are likely to have much more trouble sealing stuff which is why i reccomend floor entry into wooden outbuildings
