Terminology help please
14 Jan 2008
Staffordshire
Hello All,
Apologies if this is posted in the wrong section, but I couldn't see an obvious place for it.
What is the accepted term to describe the situation where your front door is at the top of a couple of steps? i.e my "ground floor" is about 500mm above the level of my drive / the road outside.
I want to replace the existing brick-built porch on the front of the house with a predominantly-glazed one, and one of the stipulations on the local council planning and building control website is that the porch can be no more than 3 metres above ground level.
What is considered "ground level" anyway? The level of the driveway (and most of the rest of the borough)? Or the bit adjoining my house?
I guess in this instance ground level is exactly what it is and bears no relevance to dpc or floor level as it is a planning issue.
So, i would say the ground abutting the perimeter of building. In your instance it will be the ground abutting the proposed porch.
the ground is ground level and your floor is ground floor.
