- Joined
- 7 Jan 2022
- Messages
- 6
- Reaction score
- 0
- Country
OK, this is odd.
I am setting up a Texecom alarm system. Pretty new to this setup, but I know my way around electronics in general.
Premier Elite 48 (V5.06.00LS1), Premier Elite SMK keypads, 32XP-W wireless expander (V3.1.10). Chatting to panel via Wintex 7.2 via Serial>USB converter. Mostly going OK. I am just connecting up one part of the system at a time, as I learn. Near-vertical learning curve!
I had the 32XP-W going OK, "learned" three wireless door switches to it and could see them all nicely responding on the Ricochet app. What fun! I was in the process of connecting up a Premier Elite OH-W wireless fire alarm, when I lost the PC connection. In bringing it back up, I managed to get the panel and Wintex out of sync. Although all the comms cabling was in place and the keypads continue to work fine, I could not communicate with the 32XP-W. All the busy lights still flash, end even the wireless door switches still light the row of red diagnostic LEDs, as before.
Since I hadn't done much setup, I decided to retrace my steps a little; fully power down, Press and hold Panel Reload Defaults, and start over. I have done the basic setup again, including the initial "Confirm Devices" stage, which shows one keypad and the 32XP-W expander on Net 1 as expected.
I go into "Learn Ricochet">"Learn Device Zone 009 N1, E1">"yes" and now I get a low "No/error" bleep rather than the previous 20 second countdown while I learned the devices to the 32XP-W. None of the zones 9-40 will accept the command to learn a new wireless device.
I have been through the "All Devices Deleted" screen, in case tehre was conflict, there, but still cannot relearn wireless devices (the panel won't even try - "low/beep/error" sound. I have tried reseting the wireless switches by removing the batteries, but I am pretty sure that the problem is between the panel and the 32XP-W.
There are no real clues in the log. It doesn't seem to record detailed wireless config attempts. The Ricochet graphical app now only reports the 32XP-W alone (no remote sensors), and responds as one would expect to the tamper circuit being opened and closed, so clearly the panel knows the 32XP-W is still there.
<ARGH!> What am I doing wrong? I feel like I need some sort of global 32XP-W "reset" but I cannot find such a command. Any help or ideas hugely appreciated.
Probably time for bed, now!![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
UPDATE WAIT! It's back, now. I attempted to resend EVERYTHING from Wintex, and now the 32XP-W is accepting wireless learning again. Hmm, wish I knew what I did wrong, there...
