Texecom 64W installation
11 Oct 2018
hi, just completed my install, not too many problems and all seems ok. Does anyone know if it’s possible to connect a 2nd wireless bell box to the system. I can’t see anything in the documentation either way ....
Cheers
In theory if no zones had wireless door contacts or othe detectors each zone can have a wireless bell box.
So that’s 32 wireless bell boxes on the 64 w as supplied and 64 if you add another 32xp wireless expander being the max.
Might be a little extreme
Thanks for that!..... I was only thinking about a 2nd for the rear of the house instead of the usual dummy.
I have set up the quick arm feature on my system, arming works fine. When disarming(without activating entry/exit) then it still asks me if I want to disarm the system. I’m sure that on a previous Veritas wired system, unsettling was simply a case of entering your code. Does this make sense.?
Just presumed cos they’re both Texecom units that they would behave the same way ....
The Premier Elite is a completely different animal but you can auto yes on the premier elite panel to make it similar.
Sorry SecureIam but I’m not sure where you mean. I have set the quick arm on both my wireless keypads - are you talking about another option setting elsewhere?
