hi
In the process of installing a texecom 48 panel
I have wired the window shock sensors as "double pole" using a separate
tamper circuit (2 X closed loop - 4 wires & power)
here comes the prob.
i have Texecom Prestige AMDT PIRs from reading the manual i believe it should only be hooked up using T/EOL (triple EOL alarm, tamper & mask)
trying to get my head around this...am i correct.....and would it be best practice using a fully supervised loop, (2 wires & power)
Power OV & 12V as per normal, then only one pair of cores to the T-EOL (two terminals on pir) i have each pir on a separate zone so when programming i can chose the T/EOL option
or any other suggestions would be greatly appreciated
thank you
thank you
