    Dismiss Notice
Texecom Connect internet connection speed
Discussion in 'Alarms, CCTV & Telephones' started by Beverly27, 25 Mar 2021.
  1. Beverly27
    Beverly27
    21 Feb 2019
    68
    Thanks Received:
    Country:
    Is the Texecom Connect's internet speed capped at 100mbps? I haven't been able to find anything from Texecom which tells me, but it doesn't seem to allow 1gbps and so I wondered if this is the norm or if mine is faulty. Thanks.
  2. Sally2000
    Sally2000
    6 Feb 2013
    445
    Thanks Received:
    43
    London
    Country:
    It's not a question of 'capping'. It connects at 100Mb/s, as many simple devices do. There is no need for it to connect at 1Gb/s. Even 100Mb/s is far faster than it needs for the small amount of data it passes.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. GalaxyGuy
    GalaxyGuy
    7 Jan 2014
    863
    Thanks Received:
    138
    Fife
    Country:
    Many of these systems have ancient designs that are passing serial data at 9.6k to bolted on network interfaces, so even the 100Mb/s network will never be fully utilised.
    • Thanks Thanks x 1
  5. Beverly27
    Beverly27
    21 Feb 2019
    68
    Thanks Received:
    Country:
    Thanks, I just wondered why my router, which has 1gbps LAN port capability, was showing the speed for the LAN the Texecom Connect is linked to as being 100mbps. I had presumed that this is because the Texecom Connect does not allow throughput at a higher speed, which of course might be because it's not required.
  6. Sponsored Links
  7. Beverly27
    Beverly27
    21 Feb 2019
    68
    Thanks Received:
    Country:
    Thanks GalaxyGuy, interesting.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
