Texecom Elite 64-W Questions
5 Feb 2016
I'm in the process of setting up an Elite-64 W which has a SmartCom attached and I have a few questions, this isn't the first system I've configured, the entire system is wireless.
SmartCom Version - The Texecom Connect mobile app works as expected but I'm used to entering passcode and pressing the 'I' icon to check the SmartCom firmware version. Currently this is showing v3.x and a green banner showing that it's up to date, but isn't the latest version 4.x and if it is why is it not available to update?
Time & Date - My understanding is that if a SmartCom is installed and working which I believe it is as the mobile app is connecting the time and date will automatically be updated. My initial tests indicated that this wasn't happening as I had to set this manually. Where can I check that this is correctly working?
No Location Text Has Been Setup - This is being displayed on the LCD keypad what is this and where do I set it, I've set values under Global System Options, System Text
Exit & Entry Sounds - Zone 10 (Wireless) is a magnetic door contact and initially when I armed the system I had the usual exit end entry tones but these are no longer happening, possibly my fiddling. Where are these configured?
My preferred way of configuring the system is using WinTex 8.2 which is working, thank you for any help that you can give.
Which version of the app are you on?
The Texecom cloud is probably the easiest way to update the smart com and panel firmware.
The location text doesn’t need filling, should stop comming up at some point regardless after partially setting up.
E/E are in several places spending on what you have.
On a live panel (built in keypad) it can be found on the keypad setup on address 1, other keypads via there address in keypad setup.
Global options there are volumes and tones of top of my head global option /system options and global options/speaker tones
