Texecom Expander Help
2 Nov 2022
Hi
Just installed a Texecom premier elite 24 metal case with an expander at a distance from the panel.
Just need to know if I can add 2 bell boxes to the expander and what connections to use on the expander to add them.
Also Just to let you know there are no other bell boxes attached to the panel, but attaching them to the expander if possible would make cabling a lot easier due to the distance.
Thanks for any help.
Yes ….BUT do you have a power supply at the expander ? , normally I would only fit one bell per expander using the aux input and the outputs ….how far is the expander from the control panel and what cable is it run in ?
could measure the voltage drop at the expander, but two bells definitely needs a psu at the expander end unless they are run in SCB mode and have no back lights and less than 100M.
Thanks for the advice guys.
I think I am going to have to rethink this setup
