Texecom PIR Sensors
16 Sep 2011
Durham
I'm looking for Texecom Elite PIR sensors to use in kitchen, lounge, passage and second floor landing, I have no budget for the sensors so which one is the best to use?
I've used the Premier Elite AMQD on a couple of installs without a problem.
They're about £15 each and dead easy to wire as they're T-EOL. No false alarms from the kitchen (hob etc). They look decent too.
If you need a dual tech they do one that looks the same.
The difference between AMQD and QD is anti-masking where it will still detect if someone tries to cover up the sensor?
So either two will do?
For a start you don't say what control panel you will be fitting these detectors on, just hope the panel supports eol wiring or your wasting your money.plus why would you fit antimask detectors in your own domestic property ? :shock:
Control panel is Texecom Premier Elite 24
