    Dismiss Notice
Texecom Premier 48 wiring
Discussion in 'Alarms, CCTV & Telephones' started by EddyP, 8 Feb 2009.
  1. EddyP
    EddyP
    7 Feb 2008
    160
    Thanks Received:
    Country:
    Hopefully someone here will be able to guide me, as I haven't bought the alarm yet I don't have the installers manual, so i'm not sure about some of the cabling needs, and i'm trying to run all my cables now before my plasterer comes next week.
    I'm planning the following system:
    Premier 48 panel
    RKP downstairs, near this will be a PIR and mag door contact for the main entry door.
    RKP upstairs in the hall way, near this will be a PIR
    Smoke detectors - one in the lounge, one in the hall way.
    There then will be seperate areas on the alarm, including more RKPs, PIRs and smoke detectors.
    The main question I have is, what can share wiring, or does each item need its own cable back to the panel?
    I've already put 100m of 8 core into the house, wondering how much more i'm going to need.
  2. Sponsored Links
  3. RF Lighting
    RF Lighting
    31 Mar 2006
    19,990
    Thanks Received:
    1,354
    Leeds
    Country:
    You only need a 4 core to each detector.
    You can take a single 4 core from the panel and loop it round all the network devices such as keypads, zone expanders etc.
    If you are going to be adding more detectors etc, in the future, then it might be worth having a look at running a cable in now for a zone expander, and connecting all the additional detectors to there.
    If you add your email address to your profile, I can send you a copy of the installation manual to have a browse of.
  4. breezer
    breezer
    3 Jan 2003
    23,324
    Thanks Received:
    30
    Sussex
    Country:
    ideally 1 cable / device.
    You can put up to 3 powered detection devices on an 8 core if they have shunt and end of line resistors.
    Problem can be if at a later dat 1 cable gets damaged, you have just lost 3 detecors, but if you had 1 cable / device you would only lose one device.
    also the cost of the cable............its so cheap i would suggest 1 cable / device
  5. EddyP
    EddyP
    7 Feb 2008
    160
    Thanks Received:
    Country:
    Thanks for the info guys. I'll get some more cable then and put one to each device.
    RF - I've added my email address, thanks the manual will be very useful.
    Wheres the best place to buy texecom bits from? I've seen numerous different prices.
  6. DIYerHELP
    DIYerHELP
    2 Nov 2006
    274
    Thanks Received:
    5
    Wiltshire
    Country:
  7. Sponsored Links
  8. rebuke
    rebuke
    4 Nov 2008
    872
    Thanks Received:
    25
    Cambridgeshire
    Country:
    I'm quite prepared to be wrong, not being an alarm installer etc, but my understanding was that to do it properly for a powered detector you needed 6 core - 2 for the zone contact itself, 2 for power (+V and ground), and 2 for the tamper circuit.
    Only way I could see using less would be if you did a loop and came back to the panel, so sent the tamper through the loop saving a wire, but that would still need 5 surely?
  9. RF Lighting
    RF Lighting
    31 Mar 2006
    19,990
    Thanks Received:
    1,354
    Leeds
    Country:
    The premier uses resistors at the detector.
    Using a single pair it can signal to the panel open circuit (tamper), short circuit (tamper), alarm, normal, and cover tamper.
    You also need 1 pair for power.
    I'd also recommend brewtime and security warehouse. I've used alert electrical in the past too.
  10. breezer
    breezer
    3 Jan 2003
    23,324
    Thanks Received:
    30
    Sussex
    Country:
    with resistors
    without resistors
    rebuke, more info in the sticky
    edited to add pictures;
    But also as Europlex said, it depends on the installers choice
  11. Europlex
    Europlex
    20 Nov 2007
    2,964
    Thanks Received:
    268
    Country:
    I think RF Lighting meant Double Pole or End Of Line Zones, or in other words - The Premier can also use resistors at the detector.
    Installers choice on which way to go.
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
