Texecom premier 816
28 Aug 2015
Hi all,
Just bought a house with a Texecom Premier 816, managed to set the panic alarm off...
Silenced the alarm using the prox tag and it seemed to reset ok, although the external unit has 2 red LED type lights that are flashing rapidly, seems a bit much if it was normal operation so could this indicate there is still a problem?
The unit is not displaying any problems and it seems to arm/disarm ok.
External unit = bell box?
seeing a picture/ video of the bellbox will help identify if its showing a fault and what it might be.
This is the unit outside, the 2 red LEDs are at the bottom of the white section.
Can't see them in the daytime.
Ok thanks, they are flashing rapidly at the same time as each other - rather than slowly and alternating, just seems a bit much.
