Daft question; I have a Tado central heating system and a Robot Vacuum cleaner. I can use some home automation services to set the Vacuum running if the heating goes into Away Mode on weekdays between 6am and 10am. Ie if we're all out at work, run the vacuum. I can also use the same trigger to control a relay.
Can I use the relay with an input on the alarm to trigger a set?
If so, can I program a partial set, and run a timer for 2 hours, with the timer then triggering a full set?
That would let me auto-set the alarm and allow the vacuum to run without triggering the alarm. Not sure I want to do this, but interested in whether it's possible.
