I have a Premier Elite 48 with 8 zones configured, 1 door sensor, 6 PIRs downstairs, one upstairs.
The hall PIR covers the RKP and stairs and is set to Guard Access.
I can set up a night mode (upstairs PIR set as Part 1 Omit) and this works fine, the stairs PIR acts as the entry mode in Part Set.
However, I'd like to arm via area (A is downstairs, B is upstairs, C garage). It's linked into a home automation system which does stuff when different zones are armed, so I don't want actions for area A happening at night, for example)
If I arm by A only - the part set entry mode doesn't apply, so I get an immediate alarm walking downstairs as no Entry/Exit has started.
Is there a workaround, without adding an additional keypad upstairs? What if I set the hall PIR to Entry/Exit instead of Guard Access? I guess this means a brick through the hall window would mean an entry start instead of an immediate alarm?
