I have a texecom premier 48 alarm that I have added an additional keypad to so I can alarm my garage as a separate area.
I have used the two zones to connect a door switch and a PIR, and enabled these zones in Wintex as zones 10 and 11 (and then tried again with them set to 41 and 42)
However I cannot get them to work as they state tamper. Wintex states that the resistance is greater than 100k, but when I remove one wire from the keypad and check the resistance with the multimeter they both read 2k2 ohms, and then when activated read 6k9 ohms.
The LEDs in the keypad weren't working down one side of the keypad (it seems to be faulty) so I swapped it with the house one which didn't make any difference.
Is there something I need to do to get it them to work?
Tomorrow I will try putting a resistor across the A and T terminals without the sensor to see if I get a reading
Paul
Paul
