hi folks, not quite got to the point of installing my alarm yet, but I did have floors up and I've run cable to where it all needs to go, making sure to keep as clear of mains cables as possible. a couple of short runs an inch or so from mains were unavoidable, but only for a foot or so. hopefully won't be a problem.
I plan to install the texecom permier elite 24 panel, with two keypads, two external sounders, 5 magnetic contacts, 4 shock sensors with magnetic contacts and a volt free relay module to connect the current mains smoke and heat alarms to a zone on the texecom.
comms wise, i'm gonna install the GSM module and the IP module, cos i'm a bit of a geek (Well more than a bit...)
the soudners I'm likely to go with are the stainless steel rapier, they're pricey but look pretty decent, i havent ordered them yet, or the comms modules.
judging by the above, does anyone know for sure if i'll need an external PSU or if the internal psu in the 24 metal will have enough grunt for that lot? most of the zones will be non powered so i hope not to need an external psu but not a big deal if i do.
cheers
cheers
